I am in the final stages of rebuilding a 2001 3.4 motor. Prior to my buying the car some "kind" soul had taken the engine apart and forgot to put it back together with all the parts!! 4 pistons are enough, right?
I have not been able to determine what connects to the fitting on top of the oil cooler. Appears to be a hose of approximately 6-8mm ID. It is called a breather hose in the parts diagram, but what does it breathe and where?
Thanks in advance,
LMAC
Coolant.
It is a long hose that plugs Into the coolant expansion tank drivers side engine bay.
Edited by logray
Logray is correct, it goes to the coolant tank; it is also very important as the oil cooler is the highest point in the cooling system, and any air remaining in the system will tend to collect in the oil cooler, considerably reducing its efficiency. Be sure it is connected.
