Problem: on start up and for about 5-10miles the following occurs
1.Digital dash and heater control lights pulse...at idle, the tach shows about a 50 rpm pulse, which you can feel, with air on low....turn off air and the idle settles down.
This problem goes away after about 8-10miles
2. Part two: during this time and most all the time...during a little harder than normal acceleration, mostly upgrade the battery light, comes on 5-20 seconds.
Have checked alternator output at idle 14+ volts ( New 10,000 miles ago)
Battery after shut down approx. 12.2-12.4 volts. After sitting a day....same
Changed serpentine 10,000 miles ago ( Not OEM--Auto Zone Belt)
My Thoughts: Glazed/slipping belt or weak take up idler spring.
Can anyone help???
Denny
