Hi
I have 03 996 C2 man with PCM2
Local garage have replaced the battery and since then the clock on the dashboard has stopped working - and also the sat nav thinks its about 100 miles away from where i actually am!
I have tried 1-4-8 on satnav, reset the clock etc. Status on satnav says that no satelites are being seen, is this because i have not reset it properly or could the antenna be bust?
Have disconnected battery and removed the three fuses
Can anyone help please with a definative sequence of actions to i would over the moon
Many thanks in advance
Rgds
Jonathan
Edited by jml3p
If memory serves, you Nav system will reset itself after short time. Pulling the fuses and or battery cable makes it act goofy for a bit, but it self corrects.
