Guys,
Ive just fitted the Techart type 3 rear spoiler to my 2006 C4S (without instructions) and there does seem anywhere to fit the fan. Is this an engine cooling fan, as Im thinking of leaving it off. Also I get a rear brake light fail message on each start. Any help would be much appreciated.
You will need a different wiring harness for a fixed wing vs. the stock wing (this has been covered here many times before).
The fan on the stock wing is an engine air purge fan - it pulls cool air into the engine compartment when the engine gets hot. Personally I would try to find a way to keep it.
