Do you mean "996 573 929 01 1"? That doesn't sound like a valid part number, typically if there is a suffix on there it will be two or three digits, but I've never seen just 1 digit.
996 573 929 01 is the only P/N I show...
996 573 929 01 supersedes (replaces) 996 573 929 00.
If you have a new 996 573 929 00 it should work OK.
Sometimes the superseded parts can be "redesigned" for improvement.
Or sometimes the superseded (newer) part numbers just replace something that is no longer available and it is the same part functionally.
