Hi Guys,
Anyone has experience removing the side pillar interior trim? there is a rattling sound coming from it and hoping to have a look at the inside.
But when i started tugging at the trims, it seems to be fixed to the airbag.....really concern that i may break something if i pull any harder.
Any tips will be greatly appreciated
Chers
the part of the trim that says air bag is a cover. You have to pry that cap off and you will see a torx screw. Just unscrew that and the trim will come right off. That's if you're talking about the a-pillar.
Hi Toptier, thanks for the tip,
Just to share with all fellow owners,
The unusual creaking sound was actually due to stress on the camber screw, all we did was had the car rest at normal height and with all four wheels on the ground, loosen it and tighten it back again.
All the noises and creaking sound from the trims went away.
I think there is a term for it, read this somewhere in the forum and it really works.
Basically just remember if you do anything to control arms or had one replaced, drive around to let the rubber set in, then loosen the bolts and tighten it again.
Cheers
