Does anyone know where I can get a wiring diagram for the Xenon headlights on a 2004 996 (GT3). The PO put in some sort of aftermarket lights and I'd like to reverse the process.
:welcome:
Are you sure they changed the wiring?
After getting in an accident which broke the passenger HID headlight the PO replaced the passenger HID headlight (with washer) with a non HID light (w/o washer). To get the lights to look the same, he then converted both lights to HID using an aftermarket HID kit (he removed the stock HID components from the good light and replaced with aftermarket). I found a used passenger HID light and plan to put it in, but I need the wiring diagram to 1) undue any connection changes he may have made to both sides for the aftermarket kit and (2) to remove the aftermarket kit from the drivers side and replace with stock HID components.
