I have a 98 Boxster with a tiptronic . I recently replaced the regulator in the driver side door. Now every time I lock the doors it automatically unlocks. This happens with the remote or when using the key. Thank you for your help in advance.
There were two black plastic wire plugs that go to the passenger door inside handle. One goes to the light, one to the handle. I'd pull the door panel off and check those as well as the wiring to the door lock, you might have nicked or cut something when you did the regulator.
