Please help! The cams on my GT3 is off a few degrees and I need to do the cam alignment. Could anyone tell me if the GT3 cam setting no difference from normal 997 engine? The same alignment procedure and tools will work?
Are you looking at "camshaft deviation" values on a Durametric or PIWIS system, or are you using some other methodology?
The engine lost its power after overheat. Everything fixed, waterhose replaced and compression tested OK but the P0016 and P0018 code remains. I do not have PIWIS and just try to reset the cam at TDC and see if the CAM really off....
