Take the car back to the dealer - they will need a PIWIS2 to sort out the fault.
loren,thanks for reply...
do you have any information about pdk??
Very little. All of the diagnostic information on the new cars is "electronic" in PIWIS or PIWIS2. So you have to have a car to hook it up to to see the information.
Do you mind to share the information with me??=)
i have check the transmission oil level and plug in the piwis,then i get the 'P0841 pressure sensor 1 implausible value',
i don't the document to describe what does this fault code means,and what are need to do....so any idea???
and one more thing,do you know how to adapt the turbo boost pressure adjuster???thank.... :lol:
You need to use the PIWIS Fault Finding program.
ya loren....i have use the piwis tester to diagnosthe car and get the code that i mantion before....do you know what does the code mean???thank...
