Help/advice needed: I am seriously considering purchasing a 2004 911 Carrera 4S Cabriolet (manual trans). The car has ~85k miles on it. Brand new engine installed by certified Porsche dealer 2 months ago - engine has very low miles on it (< 500) - car comes with 2 year, unlimited mileage warranty on the engine (from the dealer). Rear main seal has been replaced and the car appears to be in very good condition. Any one have experience with purchases such as this - any advice or words of wisdom? This will be my first 911 after owning Boxsters, this is a lifetime dream and I don't want to screw it up. Any help, very much appreciated.
Edited by 411ona911
New engine from Porsche with warranty is a good thing. Not sure why the RMS has "been replaced?" The new engine came with a new RMS, did they have to repalce that one. All in all sounds like a great option for a car to buy. You should still have a PPI done for any other problems.
Why would RMS be replaced if it was a new engine only 2 months old? As for your question, my 02 C4S had the engine replaced in 2006 by Porsche with about 65 K miles. It now has 95K miles and no issues whatsoever. If it is a Porsche Reman it has the revised IMS bearing which appears to be doing well however, it is a machine and therefore nothing is absolute.
You beat me to it :notworthy:
Thank you for the reply Dharn55. I am having a PPI done at an Authorized Porsche Dealer (different than the one that replaced the engine) on Monday. The engine is a 'new '04', according to the dealer and the RMS was done prior to the engine replacement, according to the warranty records, and then again when the engine was replaced. Additional warranty information showed that there has been 4 warranty services on the vehicle - RMS, Engine oil leak fixed, convertible top liner 'refitted' and engine replaced. All items were covered by Porsche, the engine replacement was noted as being covered under 'Goodwill'. Thank you again for the reply.
Thank you for the reply goldenwarrior1. The engine is a 'new '04', according to the dealer and the RMS was done prior to the engine replacement, according to the warranty records, and then again when the engine was replaced. Additional warranty information showed that there has been 4 warranty services on the vehicle - RMS, Engine oil leak fixed, convertible top liner 'refitted' and engine replaced. All items were covered by Porsche, the engine replacement was noted as being covered under 'Goodwill'. Thanks for the info on your vehicle, documented experiences help with the decision process. I am having a PPI done on Monday at an authorized dealer so I will see how it goes.
