Im New Here, First Post :clapping: :renntech:
:help: hey guys i Need Help With the Wiring For the 2009 xenon Headlights to fit a 2003 Cayenne S. the only reason im doing the conversion is because my brother owns a body shop in southern Califronia, we did everything now where just stuck on the wiring...i know people have done this before any help would great thanks in advanced. :thumbup:
Edited by sikcyacayenne
  • 2 months later...
I have done the conversion as well, but with regular HID headlights. So, while I can't give you an answer I can tell you how I found out my connections: Take a volt meter and measure every contact from the connector while switching on the lights one by one. Next, take the headlight and use the continuity tester to find out where all the connections end up. Now just cut the plug and connect the cables acordingly.
I have a feeling the Xenon lights are more complicated and it might not work but wanted to shre it anyway.
