I've got an unusual problem with my 2002 Boxster S CDR-220 audio system. Stated simply, when I listen to the radio head unit, I receive no sound from the laft dash speaker at all. Yet, when I switch the source to the single CD player within the radio unit, the same speaker works just fine. So, obviously it's not the speaker itself. But, would it be the receiver, the amplifier, the wiring, or something completely different?
I had a similar issue and when I replaced my iginition switch all was normal. I swapped radios with a friend and my unit worked fine in his dash and his radio had the same issue in mine. We even swapped AMPs to be sure. Without knowing or thinking the switch and radio were related, I got around to replacing the ignition switch and voila! The switch also fixed some other quirky things as well all electrical.
