I have 2 problems with my drivers side view mirror. The easy one is that the mirror is coming off the backing. What kind of glue should I use to replace it that will stand up to weather extremes and still stay stuck.
My other issue is that the piece which holds the mirror (and alo is the mirror heater) is barely fixed to its post. It wobbles ridiculously and the clips that hold it to the unit do not seem to hold firmly. Does anyone have an easy fix for this?
Thanks.
It sounds like the you need to replace the mirror glass with the retaining assembly that then clips onto the power mirror motor. Over time the heater grid can cause the mirror to de-laminate from the glass. The part number varies greatly depending on your VIN number.
