Does anybody know how adjust the maximum turning angle? I'm getting a little rub in the fenders when I'm at the lock. I was hoping to just adjust the lock to be a degree or two sooner to prevent the rub. I would assume the adjustment is on the rack itself but need some more specific advice.
Thanks.
Thanks.
Are you lowered? Wide wheels? Spacers? The common solution to rubbing with any of these mods is to roll your fender lip. I'm not aware of any adjustment that can be made to the steering rack or supporting parts that would alleviate the rubbing.
Mark
