I recently installed the double din kit from treullionaire (greatly recommended). After I finished the installation, I realized I had left some CDs in the cd changer. Not wanting to reinstall the stock radio just to power the CD changer, I removed it and powered it manually. I thought this picture would help someone in a similar situation.
First, remove the cd changer from the trunk (just two screws on the mount). On the bottom, you will find a couple of common RCA audio cables and one multi-pin cable. Using a wall-wart or some other 12V source, connect the negative end, or ground, to the ring of the harness. With the ring union facing down, the +12V pin will be the one in the middle right. See the attached picture.
If you did it right, the changer motor will make some noises, and you will be able to eject the magazine.
