Does anyone have the part numbers for the whole Cigarette lighter assembly for the 986/996.
I'm planning on adding a second Cigarette lighter on my Boxster
Thanks in advance,
-Duster
996 652 101 00 Cigarette Lighter (to MY01) ($9.83 Retail as of Dec 2004)
999 650 284 40 Plug Socket ($0.40 Retail as of Dec 2004)
999 652 735 12 Connector($0.29 Retail as of Dec 2004)
How are your going to drive with a cigarette in each hand.
If you wanted it lighted you also need 996 652 102 01.
Might consider the non smoker socket - not sure if that holds plugs better than the lighter socket.
Thanks Loren & Jeff!
What is the non-smoker socket and part number?
So, what I'm trying to accomplise is to add a second lighter for another accessory such as to power my GPS unit. This means I need to splice into the power for the original lighter.
I believe I need the part numbers for the plug that plugs into the lighter socket along with 3 connector power pins for wire harness I need to make.
Thanks in advance,
Duster
