I've done a search but didn't find anything about replacing the belt. I've got a 06 C2 and was trying to figure out which pully is the tensioner. Non of them look as though they would move enough to get the belt off. Any help would be appreciated. Picture would be great. Thanks.
  • 4 years later...
Does anyone know the torque for the screw to mount the Pulley to the engine block?  I know the Generator Pulley is 33 ft-lbs.
Forget it.  I found it: http://rennlist.com/forums/996-forum/852358-idler-pulley-torque-question.html
quote -
"simply install the bolts and tighten to 34 ft-lb (46 Nm) for the upper bolt if it's an M10x145 (8.8) bolt or 48 ft-lb (65 Nm) if it's an M10x145 (10.9). The lower pulley is tightened to 17 ft-lb (23 Nm)."
Edited by racerken
