Just thinking about getting a code reader from the Durametrics for my 08 Cayenne S, (non-turbo) 4.8l ...but DURAMETRICS has many different kits, connectors, cables, etc, ... is anyone better (more usefull) than other? ... does any one have experience with them?, I appreciate your input!
Hi there. Great product.
Assuming you don't work in a shop and are just an owner the enthusiast version will work fine. It works on a limited number of cars, so if you have friends with cars you want to use it on as well it will be limited to the number of cars you can do that with. If you need to plug it into more cars get the pro kit.
The other cable options are for older cars or professional shops/racers.
Just make sure your model year is covered.
I think the above is all pretty well spelled out on the Durametric website, actually.
http://www.durametric.com/buyus.aspx
