Hello everyone,
I want to buy Cayenne turbo 2004 , and i'm intending to make a full body conversion to 08 models.
Any issues that usually comes with 2004 models? Any recommendations ?
Get your dealer to do a compression test. if difference between cylinders more than 1.5bar dont buy.
Edited by SA321
Well, since you asked for recommendations, I'd recommend that you buy a 2008 instead of converting a 2004 to a 2008 body. That conversion will be expensive. The 2008 models have fewer issues than the 2004 models in general. It might cost you a little more up front, but it will probably be worth it in the long run.
