75mph on the interstate and the red LED on my temperature gauge starts blinking.
Before I can get to the next exit my check engine light (CEL) starts rapidly flashing.
I put it in neutral and coast off to the shoulder and the car shuts off and every light on the dash comes on.
I wait 30 minutes but the car will not turn over again, but it really wants to. It says "vrig-jig-jig-jig-jig-j-j-jig"
Please tell me what's wrong with my Boxcutter? Tell me what to do, I'll do it. I will jack this thing up and pull out whatever you want me to. I will buy parts, I will replace them- I will suck your **** before but I go to the Porsche dealer.
(Please don't tell me I have to replace the engine. I will hunt you down and kill you. haha, just kidding... well not really)
Edited by 1999 Boxcutter
Maybe, maybe not.
Here is what I would check out:
In order of ease: Is there any oil in your coolant -- it will look a little milky -- chocolate milkshake -- maybe a little maybe a lot.
If not -- then check to see if your serperntine belt is good order.
You could have a pulley that went out preventing the belt from turning -- which would prevent you from starting by not allowing the crank to turn by the starter.
You could also have had a water pump go out. is there any leaks there -- or yellow crusty stuff around it?
beyond this -- check your oil filter -- you can remove it without loosing much oil.
open it up and see if there are any particulates.
beyond this -- things get a lot more complicated.
Mike
