I'm mid-coolant pipe upgrade, and after getting all the way down to the coolant pipes I can't find the coolant drain plug under the car. I have an 04 Cayenne S. Anyone know where it is at specifically?
You will need to remove the belly pan, unbolt the back of the front valance and then remove the radiator support bar. All straightforward, The coolant drain (often described as blue) is on the passenger side of the radiator. Good luck. Turns out my 2006 twin turbo doesnt have a drain and I had to suck it out of holes I drilled in the old plastic coolant pipes
PKN
Thanks, it was indeed there, but it needed a larger alan wrench than a standard set comes with... I went to a local auto parts store and they didn't carry such a thing, so I did the same as you... drilled some holes and used a $4 siphon pump to get most of it. I figured everything was soaked in coolant anyway so what harm would a little more do : )
