I know this sounds stupid, but I was relocating the AC control unit and radio in my MY98 to the lower storage compartment, and when I was getting ready to put everything back together, I noticed a loose plug near the bottom of the storage area (see pics below). Now, the dome light and the windows are not working. Seems like everthing else is O.K.
This is a bit of a problem, because the windows were partly down, and I can't get them back up. I'm going out of town tomorrow for a couple of days, and I sure would like to fix this tonight. Anyone got a clue where the other end of the plug is?
Thanks.
Edited by doughep
Im pretty sure that plug is completely unrelated. You might want to check the switch on your cabtop latch. If that switch goes bad it wont allow you to raise the windows. Try sticking your finger up in the hole where the hook usually goes and trying the windows at the same time. When you push down on the switch you should hear two clicks at different stages of depressing the switch.
