My new-to-me 2003 996 C4 came with the stock CDR23, MOST, amp in front trunk, dash speakers, rear speakers, and door woofers. My front left (driver's side) speaker makes very little sound - when I isolate it with fader/balance control, it mostly sounds like it is just making sound from the tweeter. I removed the speaker and inspected it, and the wiring and speakers look fine (visually).
Can anyone offer advice on how to diagnose what my issue is? ie: bad speaker, bad amp, bad head, bad wiring, etc.?
I'll be doing an upgrade to a PCM2 soon and want to get the speaker issue resolved by then.
Cheers.
BTW - great forum!
You could start by using the passenger side speaker to isolate the speaker aspect assuming it works correctly. If the problem persists, next would be the wiring, amp, etc.
If you have a DC voltmeter, you can measure the voltage at the door speakers. Normal speaker voltage is between 5-15 volts. Put on some music and the meter should dance like a VU meter. Most likely you've got a bad speaker coil and need to replace the speaker. It's unusual (but not impossible) for a single channel to go out on a multi-channel amp.
