So I am having a problem with my 03 boxster (2.7L, 5speed).
Pulled it out of the garage last week, as I was waiting for the garage door to close the car started stuttering and then engine shut off.
Tried to restart, it cranks but engine won't run.
Here is what I have done so far.
1) Check for codes - No Codes present
2) Replaced battery with a new one
3) Replaced DME, Ignition/O2, Blower Engine Comp and Fuel Pump Relays with new ones
4) New Ignition switch
5) Added 2 gallons of gas (just in case Fuel Gauge is bad)
Car still wont start! I left it cranking for >15 seconds and was able to get engine run for a few seconds, but it felt as if only 1 or 2 cylinders were running, then it shut off and won't start. Still no codes present.
Has anyone had a similar issue? If so how did you get it fixed? What else should I check? Thanks!
Edited by apac
