I just installed the X74 on my 2003 C2 and now seem to be stuck with -1/2 degree camber in the front maxed out. While this happenes to be right at spec I was hoping for more as I run r compound tires. It seems I had more range with the stock struts. After lowering I expected to get at least 1-1.5 out of it. Is is possible that it was installed incorrectly?
Edited by 1fastline
what was your alignment before the X74?
you should be able to get more. -0.5 most stock cars can get.
it is possible that something could have been installed correctly.
also, sometimes the car needs to "settle" after suspension installation.
