metal shavings the size of a dime. Looks as though someone with a wood plane has been inside the engine?!? This was stuck to the handy magnetic drain plug that I got from LN. Any guesses as to the cause/source of the filings and shavings?
Hard to tell from the first fuzzy pic, it almost looks like shavings from the plug itself.
And the second pic, perhaps spark tube shaving - looks plastic???
if you're seeing metal the size of a dime and you're tearing the engine down I'm pretty sure it will jump out at you once you've gotten in far enough.
Edited by logray
