I have a GT2 rear sway bar due in tomorrow for my Turbo. On other cars that I've installed sways, the instructions said to use a synthetic grease (I use Mobil 1 sythetic grease). This was probably because these cars had rubber bushings instead of polyurethane.
I'm not sure if the bushings that come with the GT2 sway bar are poly or rubber but should I grease them?
Yes, use a small amount of rubber friendly lubricant on the inner side of the bushings, otherwise they will squeak after a while.
