got code p0134 02 sensor ahead of catalytic converter, does anyone have a picture or diagram showing the exact one that needs to be relplaced. i do know that bank 1 is on the passenger side.
I don't have a picture.. but you look under the car, the 2 sensor immediately after the engine is easily accessible compare. The 2 aft of catalytic converter are in a very tight sport.
always change both fronts at the same time.
