I just had my mechanic program a new key for the Targa. Now, when you hit the trunk release, it will unlock the doors but not the rear trunk. I have listened closely but hear no noise indicating attempted release of the mechanism. I'm not sure if it is just a coincidence and might be an actuator. Also, you can release the trunk with the button by the driver's seat. If anyone has an idea of what is wrong, I would greatly appreciate the information.
Porschemike
:welcome:
Could be a binding latch too. I would look for wear and proper adjustment.
You can use the emergency release near the left rear tail light to get it open.
  • 8 months later...
How to use it? It's under the light.
Last time I cleaned the rear bulbs I saw the cable, but I don't know how to use it when the tail is closed and lights are mounted.
