My trunk lid has suddenly started to open when I use the remote to unlock the car door. The trunk lid opens as normal with the trunk release remote button but it is also opening when I press on the door release button. I also noticed today that the trunk popped open as I came to a stop in my driveway, put the car in first gear and pulled up on the emergency brake, I had not touched the key. Strange... The 'trunk lid open' indicator never comes on in the dash. I tried disconnecting the battery but the same issue returned. Anyone have any suggestions or magic reset sequences?
Thanks.
Sounds like the remote is intermittently broadcasting the open signal for the trunk. Perhaps it is a warranty item. Good luck!
Thanks.
  • 9 years later...
im having the same issue.  any resolution?  i did recently have a new key cut and programmed but the problem started a week ish after.  any help would be appreciated!
I figured it out. It was the but behind the wheel on this one. The button on the door sil was stuck in the up position. Button just got sticky! Phew!!
