Fellow Boxster pride,
My problem is the birds darting over the car feel obliged to leave their mark and 99% of the time, these find their way to the top. :soapbox:
Plain water or Windex isn't quite effective to eliminate any remnants of these "Thank You!" marks.
Car's at work daily and for some reason, these birds seem to follow everywhere I park! :censored:
How do you keep your tops black and clean? :)
Appreciate any suggestions or ideas here.
Cheers!
Cheers!
The link below has a lot of good products and education on how to care for your factory cloth top. Good luck.
DC
Click Here
We do have bad luck it seems with this. My daily car is clean as can be and I take zero care of it. My Boxster gets crapped on like once a day it seems lol. That and it just attracts dirt way easier. Or maybe just that I actually notice these things on the car I care about :)
Cheers!
I use the 303 Fabric top cleaner and protectant. Cleans up the top very nice, just spray on the cleaner and use a soft brush to work the detergent into the fabric, rinse clean. Once or twice a year I spray it down with the waterproofing treatment. In between I have used a lint roller to remove small amounts of dust or lint. I religously only use Plexus cleaner for the plastic rear window, it works great.
Car cover?
You **** betcha!
Once had a navy blue Volvo 242. My assigned parking spot was directly beneath a honeysuckle tree. Lots of red berries that had a laxative effect on the birds. This was in the early 70's when I was a renter.
My car would be covered w/bird s--t every morning during warmer months. The car cover I bought worked great! Took about 3 minutes to put on car, even less to remove.
Had elastic running through all four corners at bottom, and a mid-car eyelet an each side through which I would insert a cable to secure it. Came with pillow case type container to stow cover. Once a week would
run through washing machine.
Now have one for my Box w/black convertible top. Makes big difference. Be sure to get a BREATHABLE cover. Otherwise the car wax may develop dense white fog (like furniture polish with neglected water spills)
Have had this cover for more than 3 years now, still like new. Got it from Pelican parts, IIRC made by COVERKING. Good, better, best, type ranking. Got the BEST rated, A little pricey,
but worth every penny over the years.
Jim
Edited by jotoole
