This thing looks like a rubber hose/plug/valve and is located on the outside bottom corner of each radiator on a 986.
post-6627-0-98357300-1304740200_thumb.jp
Can anyone tell me what its purpose is?
Regards, Maurice.
Looks like the rubber plug for the drain tube. Number 19 in the part list/diagram
DC
DC:
Thanks. I was trying to figure out if the rubber plug had a one-way valve function or something. Apparently it just looks like a sealing rubber cap, as you point out, for the little drain nipple in that corner.
When I removed mine on the passenger side to replace it, it was torn up and I didn't have a spare on hand, but I was surprised that only about 8 ounces of coolant drained out the that radiator. Maybe it was because the front of the car was jacked up, about 24 inches off the ground. I made a temporary plug out of a piece of 3/8" fuel line and a cut-down bolt.
post-6627-0-53291800-1304822386_thumb.jp
As soon as I receive the replacement part, I'll install it.
Regards, Maurice.
