My ABS light turned on after the car was stored over the winter. I have done a read-out on the fault codes on the engine and found the code P0501 (Vehicle Speed No Signal) but the speedometer on the car works perfectly. I have no PSM or simular, just ABS. The car is a manual 996 C2 -00 RoW (E-gas engine). Does anyone have a clue? I can't do a ABS read-out right now because I'm away from home. And it doesn't help to lift of the battery cable for a while.
//Paer from Sweden
Edited by ParkPre
P0501 Vehicle Speed – Not in Specified Range
Possible causes:
– Open circuit or short circuit in wire from DME control module to ABS control module
– Open circuit or short circuit in wire from rear left wheel speed sensor to ABS control module
– Rear left wheel speed sensor faulty
– Pulse wheel for speed sensor damaged or contaminated with brake dust
– DME control module faulty
– ABS control module faulty
Durametric or a PST2 might be handy to narrow down the problem.
