The last time I turned on the Bi-xenon headlights in my 04 Cayenne S, one headlight is now a bright shade of purple. The other one is OK. Does anyone know what the fix for this problem is?
Zok
I agree that the bulb is on it's way out. Replace it asap before it damages the expensive ballast unit.
Think the bulb is on its tail end .. and needs to be replaced.
Thanks for the reply. I'll change it this weekend.
You should change both at the same time. HID bulbs vary in color temperature and light output over their lifespan.
