Hi All
Car 1999 manual c2 cab ABS but NO PSM
When I get on the brakes hard on the track the front left locks up while the pedal shudders as the abs is activated on the other wheel. I can also reproduce this in normal driving if I brake hard the left wheel locks while the abs controls the one on the right. A number of years ago I replaced the right wheel carrier and speed sensor with a used one. I believe I had the issue before this but cant be sure as I was not tracking the car then. I feel the car has more braking ability which I am not reaching because the wheel locks up and chirps.
Different tires and brake pads produce the same result
I had the car balanced and it is good as it was suggested as it may be a weight transfer issue. I have also noticed that the ABS light does not come on when the abs is active. The light does work.
I had some one use the Durametric on the car and no faults were found anthough the scanner had difficulty connecting to the car. if i drive in reverse aprox 10 mph and hit the brakes the front left locks up and skids it releases when the pedal is released.
I have changed the brake fluid a number of time with no difference. My brake pads ware evenly all around the car. The pads on the front and the back ware out at the same rate which is a little strange as I expect the fronts to ware out first
Does any one have any suggestions to this issue.
Thanks in advance
CRSTFR
