Coolant Pipe Failure
25 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
In an attempt to find the actual failure rate and timing of the coolant pipes - I thought a poll might be useful. Please check off only the applicable answer.. perhaps this can be made a sticky.
SINCE each question requires at least one item to be checked off - I've included as the last option an option that refers you to the next or prior section - these will be ignored when I tabulate the results.
Edited by deilenberger
So far - assuming the people who replaced the pipes as a precaution (non-failed) didn't have leaks.. it looks like 11 non-leaking systems vs 2 leaking. Hopefully more people will post their experiences - but to date - failure rate appears to be about 20% (of a very small non-scientifically valid sample.. ANY survey like this tends to get the negative responses over-represented since those people are usually pissed off..) - not good - but not as awful as one might think reading the threads on pipe failures.
