On my 996 rhe rad fans turn on only when the A/C is on. If the A/C is off, the rad fans stay off, doesn't matter how hot is the engine.
Has anybody experienced a similar problem and how can this be corrected?
Switch-on conditions for coolant or condenser blower motors
Stage 1 is switched on when the coolant temperature is > 100° C
or
there is an AC demand, the intake air temperature is > 8° C and terminal 15 is switched on.
Stage 2 is switched on when the coolant temperature is > 105° C
or
the refrigerant pressure is > 16 bar
Thanks, Loren.
I had reached 100° C, that, I thought, was already hot. I will pay attention to the fans if I get to 101° C. If everything is per specs the fans should switch on.
or
or
