Who else, besides Tarret Engineering, is making adjustable rear track arms (the lower, diagonal link that is visible from the rear of the car)?
Go to any race car fabricator. They can make you up a set in no time plus you can ask for high quality Heim Joints as the quality varies greatly.
  On 4/29/2011 at 10:49 PM, 4agdtym said:
I just got the Tarrets and will install them tomorrow. Stomski also makes one.
http://www.pelicanpa...20Boxster%20all
Has anyone played with the adjustable trailing arms? I think I'm going to be stuck using the GT3 lower control arms and adjustable track arms (thinking Tarret).
I have both GT-3 Split lower armson 4 corners and adjustable rear location arms. What your question is it for more negative camber if so the rear adjustable arms will do the trick!
