So my key fob stopped working... it won't unlock the doors. I changed the battery and still won't work. Can I open the car with the key manually? will the alarm go off if I open the door? any other ideas? My wallet is locked inside the car and I cant get to it.
What year/model is your Cayenne? What battery did you change -- on the key fob or vehicle main battery?
You absolutely can open the car with the key. If you do set an alarm off, put the key into the ignition and turn it on
PKN
