I own a 2003 c4s 3.6 L with 91,000km on it.I'm in proccess of researching new coils/plugs for it.I noticed some of my coils are slightly cracked and when it rains I get a bit of a misfiring(intermittent).The part number for the ignition coil is 997.602.102.00 made by BERU .Could somebody please verify this for me so I get the correct part.Also ,what is the part number for the plugs?I found out that Porsche uses Bosch plugs,is that true?
I've been unable to locate a good source for part numbers for my car.Any ideas/suggestions will be appreciated.I usually try to do things myself ,so any DIY tips are also welcomed.
Tx
Edited by 66bus
:welcome:
997.602.107.00 is the correct part number (for newer) coils.
999.170.223.90 is the part number for the spark plugs (FGR 5KQE0) -- Porsche uses both Beru and Bosch spark plugs.
Tx
66bus,
I suggest that you visit this Porsche website to get information on Porsche part numbers; http://www.porsche.c...partscatalogue/
The Original Porsche Parts Catalogue (PET) on CD-DVD that they offer for 9.00 USD is well worth the price.
Thanks for your reply,Loren
I'm planning on buying my parts fro PelicanParts,their on line catalog lists ignition coils for 02-05 996 C2/4 as part number:997-602-104-00-M47 and 99-01 996 C2/4 as 997-602-107-00-M47.
Is there any known difference between the two?Connector size?
Thanks.
Edited by 66bus
Thanks.
-107 is the newer part.
What about bosch coils? Any reason to choose Bosch over Beru coils?Part 0 986 221 016
I have not seen any difference between Bosch and Beru coils - and both are built to Porsche specs.
