I recently replaced the passenger window regulator on my 02 Boxster S. It "works" now as in goes up and down but at a very slow speed and kind of hangs up in the middle area. Was wondering if anyone else had this issue after replacing a regulator? Could it be that the old regulator being worn has damaged the motor? Or is it just I did a crummy adjustment job? Any info would be appreciated.
