anyone can let me know how to fix? when i replace the battery ,i forgot to turn off the ignition key.After i replaced i try to start but engine no crank no sound no nth. help
You might have to take it to the dealer to have them re set the immobilizer. They are the only ones that can do it. Hopefully you are in KL where there is a dealer..
thanks ur comment..
Try turning the key to position 1 - disconnect the battery again for 5 minutes. Reconnect the battery.
ok, i will try it. thanks alot
