About 7 years ago I bought what I still think is a 1971 911T Targa in excellent shape. However, the vin number doesn't jive with current available data. I've tended to not trust the data out there so thought I would try this forum.
I have clear title and have moved it through 3 states always registering it with clear title.
The vin is 9111118847. The same vin # is located in 3 places on the car:
1) On a plate along the window post by driver
2) On the passenger side along the lower trim under the trunk. Large plate that even refs 911E ???
3) By the spare tire embossed on a permanent panel.
Anyone figure this out. I wish to sell the car and would really like to tell a potential buyer the real story.
flightsong@earthlink.net
You cannot get much from old vins...This is about it:
For your Ex: VIN: 119111217
11 = 911
9 = 1969
1 = Coupe L or Luxury Model
11217 = Sequence or serial number usually 4 digits.....
Not much else. This info came from another article here...Do a search for VIN and you can find what little is available.
DC
Edited by therock88
In 1971 there were 3 models (in the US) - 911T, 911E, and 911S. Primarily the difference was the engine and HP.
I would have a look and try to see what engine is in the car now - look at the intakes and the engine serial number.
Hello
VIN 911 1 1 1 8847 deciphers as follows;
911 > General Type
1 > Model-Year (Not actual Calendar year as Porsche counts Cars built after August Hollidays as new Year)
1 > Enginetype; T ( E would be 2 and S would be 3 )
1 > Bodytype; Targa (Reutter/Factory)
1 > Transmission; Sportomatic (Not allways the rule)
8847 > Count#
However in 1971 Porsche Stuttgart & Tamm built around 18000 Cars/Year so the 4 Digit Countnumber isn´t a Problem.
The 2,2 should carry a Aluminum TYPSCHILD on the front trunk lid apron oppesit from the Waterbootle Neck wich should be rivetet with 4 Roundhead Alloy Rivets and there should be pressed up stamped (rissen Level):
Herst.: Dr Ing Porsche KG and Type 911T/E/S.
However in that Year Porsche changed to Dr Ing Porsche GmbH and Porsche used up the old Stock with KG (Kommandit Gesellschaft).
The best would be to contact the Factory Cardex Service or Porsche Classic to verify what I decipher.
Yet they will try to sale you the Factory Cardex Delivery Sheet "Geburtsurkunde" wich will contain alle Data from the Orderbook. However that money for the cardex could be better spend in good Books like Brad Johnsons Guide to Athentency or Paul Freres 911Story.
To Verify that the VIN is correct you need to check the Bodynumber wich isn´t the VIN.
These Number is stamped to the lower dash panel under Radio Cutout. To unhide the right (Offhand/Passenger) Kneepad needs to be unscrewed (3 Nuts with 10mm Wrench 2 Minute Work if done once (Know How), except AC Knee panels)
The engine used in a 1971 T Sportomatic would be a Type 911/06 and Count# 611 9001 to 9XXX.
The 911/06 should have Zenith TIN Carbs and a Marelli Distrubutor. On some US Cars the aircleaner was upgraded to Injection Version with Cold Start fuel Sprayer Rail.
Those Zenith Carbs tend to get eaten up by modern fuels with MTBE or high percentage Alcaholics. So mostly you will find a Set Weber IDT.
Grüsse
