I have a 2002 911 (996) Cab. Original owner. 78,000 miles. Over the last few months I have noticed a squeak coming from the front right. Noticable mainly at low speeds. It is now VERY noticable and if I push down on the front right it squeaks. Questions: How can i tell if it is the control arm or a bearing? Are these projects I can tackle myself (my dealer wants $950 for control arm)? If one has gone....do I assume they are all about to go? What other costs given my mileage may I be instore for?
:welcome:
Check the upper strut mounting too. They are known to work loose.
Thanks Loren, I will look at that.
No problem. I am bringing it in to Porsche next week for a diagnosis. I will let you know.
My issue appears to be related to the wishbone ball joint. MY03 p/n for the wishbone assembly is 996 341 053 07. I don't know what that p/n crosses to for your MY or my MY00. Also don't know if just the ball joint may be replaced without swapping the larger assembly.
Jim
Just an FYI.
In early cars 1969 - 73 squeaking ball joints were not uncommon. One fix was to get a syringe and inject about 10cc of ATF into the joint.
This worked for me on multiple cars over the years.
If you have a diabetic friend that injects insulin ask for a used needle. The needles are very small (26-28gage) and you can poke it through the rubber without making a noticeable hole.
Vertex sells just the ball joint, but I am not sure how you install it. The factory one is crimped in. I know that you can replace the 944 control arm ball joints with a kit, but it involves a circ clip and epoxy, which I am not certain I would do.
You might want to ask Vertex what is involved in installing a new ball joint and see if you think that is a good way to go. I've always replaced the whole arm - new arm, with new ball joint and two new bushings.
RockAuto carries the Uro branded replacement control arm (wishbone) (p/n 99634105316) for $81.79. Thoughts?
Thanks.
Jim
Edited by telegraham
