I would appreciate your help....
I am having serious rattle from both rear windows. I am 100% sure the rattle is coming from the windows because when a apply some pressure with my hand the noise disappears.
I can feel the windows have a little play which I understand is normal, but may be I have to retighten the securing bolts just a little bit and see how it goes.
Anyone knows how to get to these bolts ? Do I have to remove the B pillar ??? I hope not ...
Anyone had this problem before??? What is the fix??
I really hate that noise, because otherwise the car feels extremely solid and rattle free.
Please assist.
Edited by mat911
You could shove some guitar picks between
the glass and rubber. After you locate the noise,
then cut up a credit card and use
the small piece.
Paul
Yes you have to remove the B pillar, under the trim and rubber window joints, you will find both window fixing nuts, taking care because this is also an adjusting system (inside-outside) more than a fixation. A pillar removal procedure is certainly on the site (same as 996.)
