Anybody know the part number for the socket that the headlight assembly plugs in to?
Mine has a broken clip, which keeps it from being securely mounted to the car. When trying to re-install the light assembly, I get a very weak connection, and the lights in the headlight either work dimly or not at all.
If it is the connector in the picture then the part number should be 999 650 150 40, same number for left and right. Double check with your parts department. Jeff
