I have a 2011 Cayenne S with PASM and steel spring suspension. I am considering lowering the car with the H&R lowering spring set, which says it will lower the car 1.2". I can get the springs for a little over $300.
My questions are: How much should I expect for labor (install springs and alignment)? Can I go to the dealership to get this done? Will I be voiding part or all of my warranty? Will the lowering put potentially too much stress on the PASM shocks?
I'm considering doing this primarily for aesthetic reasons, although I do think lowering the center of gravity a little bit will help handling (it already handles very well). It will probably never see off road activity so I'm not concerned about losing clearance.
Jason
  • 4 weeks later...
Here is what I've found out so far:
H&R springs from tire rack are $312 (part number 28938.1)
I've gotten two quotes from dealerships, one was $1,059.20 and one was $1,200 (install springs and alignment)
The independent shops have bee around $600 to install the springs and $200 for alignment.
Also from my research it sounds there is a special tool for the PASM shocks needed for the spring install.
  • 7 months later...
will all of the PASM functionality still work, raise and lower etc?
Edited by JoeA
  • 3 months later...
  • 3 months later...
Did you end up doing this? I am wondering about the result, I could be interested in doing the same thing, mostly for handling. If I had air suspension I'd spend 99% of the time in the lowest height
Hi. I am interested if you feel a big difference in comfort now after lowering? Which wheel size you have on the car? Any pictures from before and after? Thank you. Tom
