Light came on driving home tonight - just after driving over a rough section of road. Got home and shut off car. Waited a few mins and restarted. Ware light went off.
Could the rough road cause a sensor to throw a false reading? Anything i should check?
Bill
MY99 boxster
5 speed
Is there any one of the sensors more prone to fail than the others?
What is the lower ware thickness on the pads?
Thanks.
I get an fault on my now and again, once the faullt was 'hard on' for days so put car on axle stands and shorted them all out expecting the light to go out.
It did not ???
Do they have a certain resistance ? I always presumed its was just standard loop wire which is either cut or earthed as pad wears.
It did not ???
The brake wear light is turned on when any part of the circuit (all 4 wheels) is open.
Usually it is a broken sensor or bad connector.
I totally understand it's just a series circuit BUT i shorted mine at the plugs and it was still on, i know on some BMW's they have a resistor as well, thus if there's a short/damage in cabling it will also show as a fault.
This is senses open circuits and shorted circuits.
Poor Porsche design...lol
Edited by bilabonic
