We have had no rain for a while in Houston, and today driving with the top down and A/C on in my 1999 Boxster, I suddenly felt cold water splashing onto my right foot while making a right turn.
I am quite sure this is A/C condensate and wonder why it's not draining out. I believe there is a drain pipe pretty much underneath there. Would it make sense jacking up the car and blow it out with compressed air?
Edit: I DID check underneath the car and there was a small puddle of water, most likely from the A/C drain.
JP
Edited by flyingpenguin
Yes, but make sure the tube is protruding through the opening first.
Sometime folks bump it when doing stereo work or even cleaning.
Thanks Loren,
After posting I checked underneath the car and there was a small puddle of water.... At least some water is coming out. Will get underneath the car tomorrow and blow out the drain line.
JP
